RUDDOG RP691 2200kV characterization
Since datasheet for this BLDC motor is not available, I will try to characterize its properties and share it here.
Attempt to characterize BLDC motor RUDDOG RP691 2200kV due to lack of available documentation.
Phase LCR measurements summarized below.
Inductance vs measurement frequency chart:
Resistance vs measurement frequency chart:
Taken with LCR meter Hioki IM3523:
DUT:
  • Commutation with hall feedback
    kevarek02/23/2022 at 08:59 0 comments
    So I have learned that static analysis of step vs hall code will not result with usable table for commutation. Here is the table that is actually useful:
    Same table as above but sorted by step (sixstep algorithm):
    Example of waveforms during OK CW operation (this was data source to create tables above) as acquired synchronously with switching frequency (50 kHz, sampling time at 90 % of switching period):
  • Sensor connector pinout
    kevarek02/13/2022 at 13:18 0 comments
    Pin 1: Supply voltage (both 3V3 and 5V tolerant).
    Pin 2: NTC thermistor output (with respect to GND). 10kOhm @ 25 °C; Beta unknown for now.
    Pin 3: Hall 1 output. Open drain. Seems to be related to Phase A.
    Pin 4: Hall 2 output. Open drain. Seems to be related to Phase B.
    Pin 5: Hall 3 output. Open drain. Seems to be related to Phase C.
    Pin 6: Common ground.
  • Hall sensor outputs
    kevarek02/13/2022 at 13:10 0 comments
    Table with hall sensor output voltage relative to phase voltage (aka six step configuration - current step). Zero phase voltage indicates that phase is not driven by transistor half-bridge.
    Visual representation of table above.
    Hall sensors seem to be aligned in such a way that when any of hall outputs change state, commutation event shall occur (sometimes referred as 0° orientation with respect to phase zero crossing):
    Im not sure what is the benefit but apparently the other option might be 30° orientation (not relevant for this motor):
    Source: Texas Instruments - SLAA695.
View all 3 project logs
