Attention - Your MPF-IP BASIC ROM IMAGE from the Internet is bad!
A project log for Exploring the Microprofessor
A journey to explore and better understand the Multitech Microprofessor machines in my retro computer collection
michael-wesselMichael Wessel 01/19/2022 at 19:266 Comments
Preparing for my demo video of the MPF-IP BASIC, another Microprofessor MPF-IP enthusiast I was chatting with on another forum just complained that his BASIC wouldn't print properly beyond 18 characters, and that certain BASIC statements documented in the manual don't work (SON, SOFF).
I said, what do you mean? My BASIC just works fine, no issues with the printer, and SON / SOFF work flawlessly!
He then pointed me to the BASIC ROM image he was using:
https://electrickery.hosting.philpem.me.uk/comp/mpf1/doc/MPF-IPlusBasicROM.zip
I grabbed it and burned an EPROM, and indeed - this version must be a prior version and has these issues! For printouts, you'll have to limit yourself to 18 characters per line, else your printout looks as follows:
Now, my original BASIC ROM is indeed working fine, has SON / SOFF, and printing works fine beyond 18 characters:
Seems the MPF-IP BASIC got a major update. There is no obvious version number encoded in the ROM image (at least not in ASCII).
Comparing the ROMs a bit, I see that they even omitted the READY prompt in order to accommodate the patches and SON & SOFF... the new version goes to 0x1ff8, whereas the "buggy" version has 0x1ff3 as last address. So a few bytes more. They really used almost all of the 8 KBs in the 2764!
Nigel Barnes wrote 12/21/2022 at 19:26 point
Do you have a photo of your later BASIC-IP? If it's original then I'd expect some indication of version on the label.
bcrisciotti wrote 07/16/2022 at 08:36 point
ho everyone. I am desperately looking for the manual of the rom basic . Can someone help me?
Thanks for any suggestion
Michael Wessel wrote 01/20/2022 at 00:39 point
Indeed! So much that the removed the "READY" prompt in "my" version - probably to accommodate SON / SOFF and the fixes (upgrades) to the printer routine.
Ken Yap wrote 01/19/2022 at 22:43 point
Would it be possible to compare the blank bytes at the end of the ROM image? Since updates tend to use more code space, one might expect a newer version to have less free space.
Michael Wessel wrote 01/20/2022 at 00:32 point
Yes, they are different for sure... the "bad" BASIC ROM ends at 0x1ff3, where the "good" one (mine) ends at 0x1ff8 - so a few bytes more. Both ROMs use the 8 KBs in the 2764 almost fully.
Ken Yap wrote 01/20/2022 at 00:36 point
Wow they must have worked hard to squeeze it all in.
