Preparing for my demo video of the MPF-IP BASIC, another Microprofessor MPF-IP enthusiast I was chatting with on another forum just complained that his BASIC wouldn't print properly beyond 18 characters, and that certain BASIC statements documented in the manual don't work (SON, SOFF).
I said, what do you mean? My BASIC just works fine, no issues with the printer, and SON / SOFF work flawlessly!
He then pointed me to the BASIC ROM image he was using:
https://electrickery.hosting.philpem.me.uk/comp/mpf1/doc/MPF-IPlusBasicROM.zip
I grabbed it and burned an EPROM, and indeed - this version must be a prior version and has these issues! For printouts, you'll have to limit yourself to 18 characters per line, else your printout looks as follows:
Now, my original BASIC ROM is indeed working fine, has SON / SOFF, and printing works fine beyond 18 characters:
Seems the MPF-IP BASIC got a major update. There is no obvious version number encoded in the ROM image (at least not in ASCII).
Comparing the ROMs a bit, I see that they even omitted the READY prompt in order to accommodate the patches and SON & SOFF... the new version goes to 0x1ff8, whereas the "buggy" version has 0x1ff3 as last address. So a few bytes more. They really used almost all of the 8 KBs in the 2764!
Do you have a photo of your later BASIC-IP? If it's original then I'd expect some indication of version on the label.
ho everyone. I am desperately looking for the manual of the rom basic . Can someone help me?
Thanks for any suggestion
Indeed! So much that the removed the "READY" prompt in "my" version - probably to accommodate SON / SOFF and the fixes (upgrades) to the printer routine.
Would it be possible to compare the blank bytes at the end of the ROM image? Since updates tend to use more code space, one might expect a newer version to have less free space.
Yes, they are different for sure... the "bad" BASIC ROM ends at 0x1ff3, where the "good" one (mine) ends at 0x1ff8 - so a few bytes more. Both ROMs use the 8 KBs in the 2764 almost fully.
Wow they must have worked hard to squeeze it all in.
