Final RetroChallenge 2025/10 VLog Entry
10/25/2025 at 16:29 • 0 comments -
RetroChallenge YouTube Video Log Entry #2 - Automagically Rotating 3D Cube!
10/19/2025 at 16:06 • 0 commentsMaking progress:
Participating in the RetroChallenge 2025/10
10/18/2025 at 14:03 • 0 commentsTrying to get a rotating cube running on my MPF-GRAFX card for the Microprofessor:
There is a Hackaday project for this:
https://hackaday.io/project/204153-3d-graphics-on-the-microprofessor-mpf-1b
Check out the RetroChallenge 2025/10 as well:
Number Guessing Game with Text Output & Speech
08/17/2025 at 14:24 • 0 comments -
Appleman / Mandelbrot Fractal on the MPF-1B!
07/21/2025 at 01:49 • 0 commentsA good test / demo for my MPF-1 GRAFX VDP / Graphics Card - ported from https://rosettacode.org/wiki/Mandelbrot_set#Z80_Assembly
MPF-GRAFX - The World's First Graphics Card with TFT for the Microprofessor!
07/19/2025 at 23:03 • 0 commentsFollowing my recent inclination of using up left-over PCBs from previous projects, this time I found a LambdaSpeak-FS leftover PCB and started thinking. Given it's SPI, I2C and UART headers, it's actually quite a versatile "host" for all kinds of modules to be connected to its generic Z80 IO base. I already added the infamous DS3231 RTC to its I2C header on the back. Still need to write firmware support for reading and setting the clock, and for communicating with it over the Z80 databus (using port IO). Soon.
But for starters, I decided to go with the SPI header and turn this into a graphics display / "VDP" for he Microprofessor. Back in the day, there was a primitive graphics interface available for the machine, and a remake exists, but it is a heavy lift requiring a lot of retro- and somewhat difficult to source components (i.e., the MC6845 display controller).
Then, there is also https://github.com/dadecoza/arduino-mpf1-vdp, which is super minimal and only requires an ATmega 328p to produce b&w PAL or NTSC video, utilizing the TVOUT Library. But, it is low resolution, has no color, and a bit "too minimal" for my taste. A real CRT is nice, but not very practical for a little portable machine such as the Microprofessor, so, I decided to keep the footprint small and to simply add an Adafruit ST7735R 160x128 TrueColor TFT display from my stash to the LambdaSpeak-FS SPI, and go from there.
Porting the LambdaSpeak-FS ATmega 644p-based firmware was a bit more challenging, and after a bit of trial and error I decided to go with MightyCore which, to my relief, worked out of the box with the Adafruit GFX Library on the ATmega 644p @ 20 MHz. I then re-wrote the required parts of the WinAVR-based LambdaSpeak-FS firmware in Arduino with MightyCore for doing the Z80 bus IO, and after a few hours of struggling with the infamously slow GPIO operations I finally got this work (by bypassing the Arduino GPIO operation). The result can be seen here:
In the next weeks, I will add support for the RTC (given that we already have a speech synthesizer working, it would be a missed opportunity to not implement a speaking, graphical analog clock!), as well as more graphics primitives from the Adafruit GFX library. My goal is to get the Appleman / Mandelbrot fractal on the screen. Stay tuned! -
Sam Bermans' GUESS Game for the Microprofessor - With Speech!
07/12/2025 at 15:56 • 0 commentsThe code can be found here:
https://www.sbprojects.net/projects/mpf1/guess.php
And my changes (speech additions) are here:
https://github.com/lambdamikel/picoram6116/blob/main/software/mpf-1b/guess-speech.z80 -
Microprofessor-2-CPC Bus Adapter works!
07/10/2025 at 02:08 • 0 commentsI uploaded the Gerbers for the adapter here:
https://github.com/lambdamikel/LambdaSpeak
Video:
Quite a bit more neat than the big mess of wires I had previously, don't you think?![]()
This is the Voice of World Control - SP0256-AL2 on the Microprofessor!
06/29/2025 at 23:27 • 0 comments -
A New Speech Synthesizer for the Microprofessor!
06/29/2025 at 00:33 • 0 comments
Michael Wessel
