See the project logs for current progress.
30 student handsets registering 4 choices to a teacher's computer for display in class.
codev1.txtinitial basic code for microcontroller.plain - 766.00 bytes - 11/19/2016 at 17:09 |
version1.cwzOur initial prototype of the transmitter. Created using Circuit Wizard.x-wine-extension-cwz - 45.87 kB - 11/19/2016 at 17:02 |
Initially, we're looking for help with the transmitter, making it as efficient as possible. We're using a Genie microcontroller, which is configured for 4 inputs and 1 output. The output is to the IR LED. At the moment, it's got a range of around 4-5m, but we'd like to increase that to as much as possible.
We want to keep the PCB as simple as possible, sticking to through-hole soldering and a single-sided board.
We're using an education-focussed CAD package called Circuit Wizard, which allows us to code and program the chips.
Do he results need to be recorded to a computer? Another interesting method for this is to put and RGB led and IR receiver on each one. When the student pushes the button it stores the value on the device and then the teacher flood light transmits the right answer and each device lights up green or red if the answers are correct. It is not exactly the same result as you intended but might be much easier to implement as you don't need to deal with IR collisions of 2 way communication
