Boards are in
02/03/2022 at 21:39 • 0 commentsI received the first set of 3 boards from OshPark. I'm waiting on backordered parts from Mouser so I can build them up- the crimp terminals for the plug that mates with the board connector are out of stock.
I think I may change the footprints for R1 , R2, and D1. The diode and resistor diameters are a bit larger than the footprints I used to make the board, so things may get a little tight.
If I do a new version of the board it will get posted here, in the meantime, here's what the rev 01 boards look like:
Mark Rehorst
