Support for all unofficial 6502/6510 opcodes
02/03/2022 at 01:41 • 0 commentsThe latest update to the vrEmu6502 emulation library now includes (optional) support for all of the unofficial 6502/6510 opcodes.
Use CPU_6502U when creating the new VrEmu6502 instance.
6502/65C02 emulator written in standard C99 with no external dependencies.
Includes:
- Support for standard 6502/6510, 65C02, WDC65C02 and R65C02.
- Supports all unofficial ("illegal") 6502/6510 opcodes (Use model value CPU_6502U).
- Correct handling of Decimal mode.
- Accurate instruction timing.
- All WDC and Rockwell-specific 65C02 instructions.
- User-supplied I/O callbacks.
- IRQ and NMI signals.
- Multiple CPU instances.
- Instruction disassembler.
- Test runner.
Check it out here: https://github.com/visrealm/vrEmu6502
Troy Schrapel
