Not much like this has happened since last time.
I have worked with drawings and tolerances.
The gears for the planetary gearbox is now on milling order. I went with C45 and 25-30HRC heat treatment and black oxide! It should arrive in 14-days.
I did a small revison on the bearing width hole on the Planets. Incearings it slightly to 2.3mm to be able to fit the 682U-H from NSK.
The gear setup is:
Ring: 44T
Planets: 17T
Sun: 10T
Now lets finish the rest of the parts!
