Allright, today I got my Nylon PA11 - MJF printed form factor parts (The rev2 version) and everything fitted like a glove.
The milling have started (The Rev4 version) for all parts except back - front cover in 7075 and will be ready in about two weeks. I chose to run 4 sets (4 - Actuators ) and 50% black oxide parts and 50% gold oxide parts, so I can mix and match with the color scheme. :)
I have also placed an order for more bearings from NSK & NTN and additional miscellaneous titanium screws that will be needed in later assembly.
![](https://cdn.hackaday.io/images/6192911644868031751.jpg)
Simple test:
