FINALLY!!!!
04/28/2023 at 10:47 • 0 commentsThe last components got delivered... Only a lead time of more than 1 year!!!
Finally, I can continue with the prototype..
Digital I/O Board mk 2 PCB designed
02/13/2022 at 21:09 • 0 commentsDecided to make a simpler prototype of the Digital I/O Board :
Instead of having the intended STM32(F205) based board featuring nice things as :
- Onboard test programs
- Sporting fixed timed sequences
- Patterns
- Connecting to the SPI bus using over-engineered addressing decoder functionality
The board now connects directly to I2C bus but still features the desired functionality :
- 2 x 8 bit ports which can be either input or output
- 1 x 8 open switches (Opto Couplers)
- All connectors aligned with the connectors on the Raspberry Pi for easy front plate design.
