This project can be found at https://hackaday.io/project/183942-light-dice
The logic circuit drawing.
Light Dice, Where Light Logic learns how to roll....
Enhanced led display. Yes, the board is printed like that :-D
Putting a ring oscillator, some D latches, a few Nand gates and a dice display together and using only Vactrols. A video and a circuit will be forth coming.
I think you should be able to shorten your ring oscillator to three inverters :)
I need to tweak on the circuit more. As it is, its output is sequential so three inverters would only give me 3 outcomes that I can see.... Or am I having a senior moment? ;-)
I had an Eureka moment when I wrote the part on the bipolar dice ;) .
(The "fully inverted johnson counter" is actually equivalent to a ring oscillator)
The idea of full inverting was rolling around in my dreams last night.... Going to have to check out that direction :-)
Ahh haa, I did get a three latch Johnson Counter to give me six output states on Logisim. Now to see if I can get it to work with actual LL. Getting a clean enough clock has been the issue till now so wondering if I can make use of a relay oscillator as the clock.... If that works then the LL gate count will drop by a lot.
A three stage ring oscillator will give you a six state output.
Yup, I see the six states, now to get LL to work using a cleaner clock signal. Going to try a relay oscillator for that.
Impeccable schematics again :)
Thanks but I really do need to find a easy and basic cad type program. I actually hate hand drawing but learned it back in aviation school ;-)
I like to (ab)use LTSpice for that. EEschema is also not bad, especially with the new update.
Is there a reason you mirrored the photo?
Might not believe me but that is actually how the board was printed :-)
I hope you got a discount for that. 😉
Really looking forward to the circuit. Your ring oscillator trick is really neat, I am still trying to figure it whether it is possible to freeze the state of a ring oscillator somehow without having to add additional latches.
IDK, With my ring oscillator circuit there are fairly large caps in series with all seven Not gates with their charge states constantly in motion so that would be a tough nut to crack on my end. I am almost finished drawing the circuit.
