Details
Entry by: Tim
Technology: Skywater 130nm CMOS
Size: 3 DFF, 1 NAND, 1 AND, (1+ AND for clock gating) ~ 10x10µm² on the IC.
This is a submission for tinytapeout that combines 500 very tiny digital designs into a single ASIC to be manufactured by eFabless open shuttle program. The maximum allows space on the die is 100x100µm² and the design can use 8 inputs and 8 outputs. Both, of course, still rediculously oversized for a minimized electronic die!
Design entry was done using Wokwi, shown above and linked here. The design is based on the non-inverting johnson counter shown before. Since both positive and negative outputs are available, the decoding logic reduces to a AND and a NAND.
The schematic entry is converted to a verilog source by Wokwi:
assign io_out[0] = net3;
assign io_out[1] = net4;
assign io_out[2] = net5;
assign io_out[3] = net6;
and_cell gate1 (
.a (net9),
.b (net10),
.out (net4)
dff_cell flipflop2 (
.d (net3),
.clk (net12),
.q (net10)
dff_cell flipflop3 (
.d (net10),
.clk (net12),
.q (net5),
.notq (net13)
dff_cell flipflop4 (
.d (net5),
.clk (net12),
.q (net9),
.notq (net3)
nand_cell gate7 (
.a (net10),
.b (net13),
.out (net6)
and_cell gate9 (
.a (net1),
.b (net2),
.out (net12)
endmodule
Then a github action in a github repository fetches this, performs synthesis, placement, routing and layout generation.
Another design I handed in averaged 50000 cells/mm² for mixed cell types. Based on that, we can assume that the 5 cells occupy 0.0001 mm² or about 10x10µm², one percent of the allowable space. I guess this is surely the smallest electronic die, but maybe not the most efficient one.
Well played !
What about the RESET of the state ?
Yeah, somehow the DFF in Wokwi are missing a reset input. I used a non-inverting Johnson counter, hoping that they are initialized all in the same state (either 111 or 000), which are both valid.
"hoping"...
yeah it's going to go up in flames then ;-)
Very hard to make DFF cell that is not biased and will come up in a random state :) I'll take my chances.
But it's a good point regarding the Wokwi flow, I asked in the discord.
