This has been a long time, I have a lot of work for school in the background so this project slows down a bit but still persists!!
What I haven't done is the physical board due to lack of time.
But what I have done is a lot of coding!
You can see the progress in the GitHub repo but here's a little summary:
-More commands
-More fail-safe check
-More readability with the constants.h file
-3 examples
-You can now set the pan and tilt position with angles!!!!
If you are worried about the control panel well I will be making this in the vacations so in about 3 weeks.
During this time I'll update the code to feature request commands and more testing is required!
Until next time!
