CylinDraw: Rotary Plotter & Engraver
Easily create incredible artwork on any kind of cup!
This is the CylinDraw, a new tool that lets you easily create incredible art on any kind of cup!
CylinDraw essentially does 2 things: It can engrave & it can draw. And it is highly adjustable so it can do those 2 things on any kind of cup. (tumblers, wine glasses, mason jars, shot glasses, mugs with handles, or any cylindrical object tapered or not under 3” diameter & 10” tall). It can also draw on paper!
This is a large body of work. Everything was made from scratch including the HW, SW, & Firmware! (It does not use grbl). There is a lot to cover, so the introduction & demonstration video is a good place to start.
 Over the last year, I have been developing a complex project and I am excited to finally share it!
I created a brand new type of tool that I believe can make a significant contribution toward serving the creators in the cup customization space. Especially those looking to find a competitive edge and bring something new to this market.
This is the CylinDraw, it lets you easily create incredible art on any kind of cup!
As a painting tool, we have experimented and perfected techniques for drawing on multiple types of materials and coating the end result to make it dishwasher safe. (Though there is a wide world of markers and coatings out there to choose from to continue experimenting with!)
 As an engraver, CylinDraw is an order of magnitude less expensive in terms of upfront/operating/& maintenance costs when compared to a rotary laser engraver, while offering better ease of use and equivalent drawing resolution. (CylinDraw operates at 0.2mm wide stroke, lasers are 0.1-0.5mm.) Engraving is also a safer cleaner process than laser etching since fumes and fire are not a factor. Lasers must be vented to the outside because of chemical byproducts (smoke), while mechanical engravers only create physical byproducts (microparticles) which can be contained with a water pump or a shop vac.
But of equal importance to what CylinDraw does, is how it does it.
Cool hardware is still a useless brick without software, and if the software sucks then its an irritating brick. But get both things right and using the tool becomes such an effective process that you can start taking it for granted. That’s when you know something has improved your life. That was the design intent. Every aspect of this tool is designed to make the user experience painless, because I think computers should just work so you can focus on the art!
CylinDraw software is free and all-inclusive. It can convert any bitmap image like a photo or screenshot into a vector graphic (SVG) and then into a drawing-in-progress in minutes. Almost all drawings & engravings are doable in under an hour.
The system automatically makes assumptions on your behalf to streamline the process. A few examples:
  • Multicolor jobs self sort the colors by brightness so you don’t smear light colors with dark ones.
  • Drawing paths are optimized using a honed greedy algorithm.
  • SW automatically updates the motor speeds to account for cup diameter & taper.
  • Automatic connection to the tool when the USB cable is plugged in. A happy beep tells you all is well.
  • Separate user interfaces for separate functions so that all the information on screen is relevant, and the only controls you have are the ones you need.
  • No internet-of-things planned obsolescence security nightmare nonsense. CylinDraw operates entirely without internet access.
  • Custom ‘JOB’ files (machine readable g-code files) use an .svg extension so they can be viewed as thumbnails or in a browser, or they can be parsed with a viewer program that is part of the package.
Overall I think CylinDraw represents a high value proposition for what it does and I am excited to see what creative works people will come up with. I am preparing to offer kits in my store that will appeal to do-it-yourselfers as well as folks who prefer a turnkey experience.
Kit Option 1: You 3D Print + You Assemble it:  You get the 3d printable files & make them yourself. We send you all the tools, electronics & mechanical hardware. You build it using instructions online.
Kit Option 2: We 3D Print + You Assemble it: We send you all the 3d printed parts, tools, electronics...
CylinDraw_STL_Released_V2.zip
x-zip-compressed - 10.69 MB - 02/16/2022 at 20:14
Download
Shared_BOM_Stepper_Wiring (1).pdf
Adobe Portable Document Format - 945.53 kB - 02/16/2022 at 20:14
Preview
Portable Network Graphics (PNG) - 1.10 MB - 02/16/2022 at 20:14
Preview
Portable Network Graphics (PNG) - 152.96 kB - 02/16/2022 at 20:14
Preview
  • Mechanical vs Laser Engraving Showdown
    Michael Graham03/02/2022 at 15:14 0 comments
    Of the many things a CylinDraw can do, engraving tumblers excites me the most because it is the most disruptive when compared to existing tech.
    Our product is so new most people aren’t yet aware of the value our tool brings to this industry, so this article will directly compare the capabilities of a CylinDraw against a laser engraver.
    If you shop online (on say, Etsy) for a custom engraved tumbler there is a 100% chance the seller is making them using a laser engraver with a rotary table add on. That’s just the way it’s done for low volume production.
    High volume custom tumblers are usually made with a different process like screen printing, pad printing, heat transfer decals, full color digital printing (can produce gradients), or acid etching. But those processes have a costly labor intensive setup not worthwhile for a one-off tumbler.
    In the same way that 3d printing pays off against injection molding for small orders, so does physical engraving compare to the options listed above. What matters most then to a low volume process is unit cost, setup time, and of course how safe the tool is to use. So lets compare with those important criteria in mind:
    Safety Concerns:
    • Laser Engraver: “Never run the machine unattended” is listed on every laser machine manual ever made for obvious reasons. But burning things is inherently hazardous in more than one way. Lasers produce smoke & soot that must be vented to the outdoors or else filtered inside because it should not be inhaled. Either way the fumes require high cfm fans, noisy enough to call for a dedicated shop to accommodate the tool.
    • CylinDraw: Mechanical engraving is a cleaner process since fumes and fire are not a factor. The physical byproduct is microparticles which can be safely contained with a steady flow of water or a shop vac. CylinDraw can readily accommodate either option. (Winner CylinDraw)
    Startup Cost:
    • Laser Engraver: Varies greatly but you can expect to pay north of $3000 for a name brand 40W C02 laser plus another $500 for the rotary jig. But the sky is the limit for professional equipment. You can go the cheap route & get a generic K40 from eBay, if you want to trust such a device. I’ve found the hidden costs for direct-from-China CNC equipment to be substantial and usually come in the form of mystery problems with no seller support. A K40 has all the appeal to me as a $600 car from craigslist.
    • CylinDraw: At worst its $600 if you buy the machine fully assembled & deck it out with a water pump, a Dremel Stylo, & a Dremel 290. (Winner CylinDraw)
    Recurring/Maintenance Costs:
    • Laser Engraver: The software is almost always a paid subscription if you want something decent. Expect to pay in the range of ~$500 for a lifetime purchase or ~$20/month for a subscription. If you vent indoors with a filter then you have to replace the consumable filter every so often. (~$50/yr) . The tool requires regular cleaning of soot from the internals to remain safe to operate.
    • CylinDraw: CylinDraw is a sturdy little tank with free software! The only thing you’ll be replacing is your (low cost) engraving bits every so often. And perhaps annually the $4 MG-90s lifter servo. (Winner CylinDraw)
    Ease of Use:
    Laser: Powerful software options come with a harder learning curve. Also lasers take tuning and often have to burn a bunch of bottles getting the tool dialed in.
    CylinDraw: The software for the machine was designed to be as easy to use as possible. There aren’t many control parameters required. Just mechanically set the Dremel height, select the speed from a table to match your material & go. Of course using any new software has some learning curve so to counter my own bias I’ll call it a (Tie).
    Quality:
    Customers buying engraved glasses don’t care how it was made or how long it took. They only care about the quality of the result!
    • Laser: Resolution between 0.1-0.5mm. Focus of the laser has to be adjusted to achieve a specific engraving width. Can...
  • CylinDraw Can Draw on Paper!
    Michael Graham02/23/2022 at 15:15 0 comments
    Announcing a major new capability: CylinDraw makes for an excellent paper plotter!
    The hardware needed to enable this capability only requires the addition of a large tube to wrap the paper around and two rubber bands to secure the paper in place.
    We won’t sell tubes but you can use any tube 3.5-4″ (89-100mm) outer diameter & 10.5″ long, like this acrylic tube on amazon. Cardboard shipping tubes also work!
    We also just released a new software update (V2.01) to facilitate the paper drawing option along with some other nice to have features. (Details listed later).
    There are of course a variety of consumer grade paper plotters out there, so let’s use the most popular one as a basis for comparison, the AxiDraw by Evil Mad Scientist Lab
    Tabletop Space Required: What desktop footprint does the machine need.
    • AxiDraw = 17 × 3.5 inches (430 x 90 mm). The open frame by design has to be twice as deep as the paper.
    • CylinDraw = 23″ x 6.5″ (584 x 165mm). The depth of the machine is noticeably smaller on my desk and I can use the bed of the machine to store pens/paper without them being in the way. (Winner)
    Maximum Paper Size: The usable drawing space on both machines fits a standard 8.5″ x 11″ paper. This one is a (Tie) for the base version of the machines, though AxiDraw does offer a separate larger version.
    Max Drawing Speed: How fast can the machine move.
    • AxiDraw = 380 mm/s. (Marginal Winner)
    • CylinDraw = 85 mm/s.
    Note that pen drawing is typically done at <25mm/sec on both machines, so the top speed is only differentiated while the pen is lifted. Faster moves here shave off a tiny percentage of the overall job time. To CylinDraw’s credit, the rigidity of the machine enables you to make very fast drawing strokes without fear of machine wobble showing up on the paper. Though you would almost never want to draw pen strokes at high speeds because pens can only lay down ink so fast without fading.
    Versatility: How many different ways can the machine be used.
    • AxiDraw: The open frame design can draw on literally anything flat. Paper, an open notebook, a closed laptop cover, etc. Can use normal pens or fountain pens. Cannot engrave without significant modifications.
    • CylinDraw: Can draw on any type of paper you could wrap around a cylinder, but not something like a notebook. It cannot hold a fountain pen currently, but with a new part it easily could. It can readily engrave and it works on any type/size of cup of course! (Call it a Tie as this is unquantifiable)
    Drawing Resolution: The smallest controlled move the machine can make.
    • AxiDraw: Has a resolution on both axes of .0125 mm/step. (Winner)
    • CylinDraw: On paper it has .01 mm/step on the linear axis & .1 mm/step on the rotational axis on the 4″ diameter tube that I used for paper. The resolution on the rotational axis increases proportionally with smaller diameter tubes. Since pens typically draw with a stroke width of 0.1-0.5mm, the resolution is imperceptible is most cases anyway.
    Reproducibility: How well successive identical lines overlap.
    • AxiDraw: ‘Typically better than 0.005 inches (0.1 mm) at low speeds.’
    • CylinDraw: At least as good. The closely packed closed-frame designed for the rigidity needed to engrave makes for extreme reproducibility with a pen. (Call it a Tie because it is hard to measure.)
    Price: (prices as of this writing)
    • AxiDraw: $475 with free shipping, no assembly required.
    • CylinDraw: $260-$500 with free shipping, total out of pocket price depends on if you want to assemble yourself or buy it fully assembled. Most folks have opted to build it themselves from a kit. (Tie, Depends)
    Software:
    AxiDraw: Open Source ‘Inkscape + extensions’, or a small selection of alternatives like AxiDraw server. Works on Mac, Windows, and Linux computers
    CylinDraw: Open Source ‘CylinDraw Control Suite’ only. Currently only works on Window computers but a Linux option is in development....
  • Engraving Tips & Tricks #3: How to Engrave Stainless Steel
    Michael Graham02/16/2022 at 20:23 0 comments
    Engraving off the coating from a metal tumbler is one thing, but making any kind of dent in pure stainless steel tumblers is quite another.
    Engraving stainless steel is difficult because the material is so hard! This example is the best the Dremel Stylo can do on stainless… It definitely scratches it, but its much more faint than I want since the Stylo leaves behind a smooth finish & there is nothing to catch the light.
    Pure uncoated stainless is difficult to scratch! (Note this picture is of an undesirable finish, read on to see how we improved it)
    So we brought in the big guns…
    The Dremel 290 is a diamond tipped vibratory engraver that can scratch & dent pretty much anything. It leaves behind a textured sort of emboss that feels almost like a finely knurled surface but the result is high contrast and clearly visible even on a shiny all silver cup!
    First Try, I set the stroke width a bit low but immediately I could see the potential for detail of this new tool
    The tool is cheap, simple, no coolant is necessary, & seemingly it never wears out, however… it is loud! This setup is one for the garage or dedicated workshop because the sound of this tool hitting a metal cup is not ignorable. We recommend the use of ear protection. (It just occurred to me that I might be able to dampen the sound by inserting some foam or paper inside the cup. Of course you could always put a foam box around it too, that would be enough.)
    Dremel 290 has a depth control knob on the side, settings 1-5 with 5 being maximum depth. The vibration frequency is a function of your 120VAC frequency, so that is not adjustable. I choose 5 so as to get a strong mark.
    For this tool I recommend slicing images at a 0.2mm line width, then running the job at 15mm/sec @100% vibration intensity.
    An experienced engineers motto: “Slow is Safe, Safe is Fast”
    The Dremel 290 also works on a regular coated aluminum/steel bottles, again with the tangible texture.
    For reference, the black printed part model name is “ChiselMount_Dremel290_1xOPTIONAL.STL”, found among the other officially released CylinDraw Parts. The tool is held in firmly place to its mount with a couple cable ties.
    Next time we will be discussing the details of our value proposition against the established technology. CylinDraw Engraver vs Lasers!
  • Engraving Tips & Tricks #2: Cooling, Feeds, & Speeds
    Michael Graham02/16/2022 at 20:22 0 comments
    The engraving process produces ultra fine particles that are too small to see which need to be collected for human safety.
    Our original design calls for a mounted shop vacuum and a magnetically mounted Lexan shield.
    This setup is simple & works great! Though its probably best used in a garage because a shop vac can be noisy. For use in an office or apartment I wanted another option…
    So with the addition of one tiny 3d printed part, a fountain pump, & a 12″x7.5″x2″ aluminum pan I built a water cooling system!
    I also added an optional printed shield/cover shown on the left side of the machine as a splash guard just in case!
    Its an improvement all around! Its totally silent & the water cools the bit as it contains any airborne particles.
    (The appearance of an aluminum foil tray is not our #1 choice to be sure. I’ve got a design for a slick black vacuum formed tray, but I wont pull the trigger until a later time.)
    In addition to new hardware we improved our technique as well.
    We learned through iteration to make software V2 smart enough to always keep the motors energized so you never lose your rotational position, even when a job is complete.
    Keeping track of your position matters because if you lose power during a job you want to be able to pick up where you left off. But since a cup is round, there is no hard stop to home against. So I think its good practice to make a registration mark at the tool home position. A tiny dot as shown in the next picture, so you can line up your tool exactly where it was, even after powering down & removing/reinserting the cup!
    We found this necessary after breaking a few bits during or experimentation process, trying to figure out the best feeds & speeds for different materials. Fortunately, this process will be easy for you since you can copy what we know works well!
    Feeds & Speeds:
    • Tool Speed: The rotary speed of the Dremel tool; Controlled by the Dremel.
    • Feed Rate: The rate of motion of the machine; Controlled in Run Mode.
    The default feed rate is a good value for drawing with a pen, 50mm/sec. That is, the pen will draw a 50mm line (2inches) in one second. Though, short line segments will take slightly longer because the machine also controls acceleration rates.
    Acceleration control is necessary because the moving parts (tool & cup) have mass and are moving quite fast. If you try to move full speed then change direction suddenly the motor might stall & lose control of its position. The default acceleration values are adequate for 99% of cases. Though on the large glass stein in the first picture I found that I needed to reduce the acceleration rate by half.
    Below are proven save speeds & feeds for engraving different materials.
    • Glass & Ceramic: Dremel Speed = 1 Feed = 7mm/sec
    • Painted Aluminum/Steel: Dremel Speed = 2.1 Feed = 15mm/sec
    • Pure Stainless Steel: Not recommended with this tool.
    Real Stainless steel is a very hard material, well known for its resistance to rust and poor machinability. The Dremel Stylo will scratch it though the result can be more faint than would be desired, since there is no contrast as with removing a painted coating. So for this material we recommend a different tool, but that is a topic for next time!
    Feed rate control in software
    Dremel Speed Control
  • Tumbler Engraving Tips & Tricks #1: Bit Sizing
    Michael Graham02/16/2022 at 20:21 0 comments
    This winter we’ve been experimenting with our engraving process to lock down the best methods for different materials & cups. In this series I’ll be sharing some interesting tips we learned along the way in a small easily digestible format.
    First enjoy this short teaser clip & these beauties that resulted.
    How its Done
    CylinDraw’s standard engraving attachment is a mount for a corded Dremel Stylo Engraver.
    So chosen because the Dremel brand is the highest quality consumer grade rotary tool on the market. (The next step up IMO is dental drills!)
    We use the Stylo model specifically because it is so light weight.
    Tool Speed Control:
    Dremel Stylo has a rolling dial to adjust speed from “1 to 5”, and the product specifications list the RPM to range from “5,000 to 22,000 RPM”. So we approximated the tool speed at each dial setting:
    • dial 1 = 5,000 rpm* (speed may reduce under load @ dial 1)
    • dial 2 = 9,250 rpm
    • dial 3 = 13,500 rpm
    • dial 4 = 17,750 rpm
    • dial 5 = 22,000 rpm
    This information is helpful for estimating what the appropriate motor feeds and tool speeds should be. (More on that another time, its easy!)
    Bit/Burr Sizing:
    The Stylo is equipped with a spherical diamond studded engraving burr. It looks like this:
    The smallest burr size we can readily get is a 0.5mm ball end, which can engrave a 0.2mm wide line. (So measured with Mitutoyo calipers & magnifying glass!)
    Finer lines always look better, BUT jobs with fine lines take more time because there are simply more paths to travel through.
    We tested out larger bits and interestingly found that we could predict the line width using a ratio & known info to predict unknown info.
    I.e. a 0.8mm ball end burr was estimated to produce: 0.8/0.5 * 0.2 = 0.32mm line width. The actual line width was measured at 0.35mm!
    Since this estimation works so well we can reasonably be sure that a 2mm ball end burr will have an 0.8mm line width (or 2.0/0.5*0.2 = 0.8mm) for example.
    We used a 1.0 mm ball end burr on this Mando tumbler because it was so tall I didn’t want it to take forever. Overall I like how it turned out, but I know I can do better!
    I think sticking with the smaller bit sizes & spending a bit more time in the DePixelizer software could have make his features pop more. IMO finish quality is more valuable than speed, because after a cup is made no one cares how long it took, only how good it looks! So its best to work at the finest resolutions even if the job takes an hour because of it.
    A
View all 5 project logs
View all 3 instructions
ty wrote 02/24/2022 at 13:56 point
Cool!
Michael Graham wrote 02/24/2022 at 20:35 point
Thanks!
