Playing with a PPU (UA6538)
Experimenting to evaluate a NES PPU (clone) as VDP for the MRC6502
Public Chat
I'm putting a PPU clone on a rough breadboard and see what happens ... without any precautions!
I bought a cheap UA6538 from China and I'm wondering if it will work.
This is the basic idea:
Last update:  clock & video
Next step: write PPU registers
  • 1 × UA6538 A NES PPU clone of 2C07 (PAL)
  • 1 × 74LS373 OCTAL 3 STATE D-TYPE LATCHES
  • 1 × SRAM HM62256 Static RAM for the PPU (VRAM)
  • 1 × Arduino MEGA
  • PPU (PAL) clock & video
    padnest02/21/2022 at 11:01 0 comments
    PPU requires a clock signal input at pin 18 and for the UA6538 it must have a frequency of 26.601712 Mhz because it's a PAL chip.
    I don't know what are the clock signal input specifications so I'm trying to use this simple clock generator circuit:
    I'm getting just 2.2 Vpp oscillation but it seems to be ok for the PPU:
    The PPU video output cannot be connectd directly to the TV low impedance AV input: we need a video buffer circuit like this one:
    See you next time!
    Ciao!
  • ...alive, it's alive..., it's aliveeeeeeeee...​
    padnest02/20/2022 at 08:51 0 comments
    I'm feeling like the young doctor Frankenstein in moments like this.
    I have connected all signals trying to keep the wires as short as possible:
    I want to keep memory signals well separate from video out and clock generator, this is the BB main chips layout:
    After giving the power supply we got a nice PAL video signal at pin 21.
    This is the first PAL line:
    This is the PAL line #44:
    This is the last PAL line #312:
    We can move on now, see you next update!
    Ciao!
View all 2 project logs
