The wiring represents the top panel in the Frame; the support cubes and Rockwool are the bottom panel. The wiring is High Temp Fiberglass Insulated wire and high temp terminal rings.
This project was developed to utilize basic shop tools; and is heavy in hand drilling and tapping. Make sure that your work area is setup with a decent Drill Press, Hand Drill, Table Vise, and Metal Chop Saw...
having a Machining Mill is also a huge help but doesn't have to be utilized...
Also, You'll need various (replaceable) deburring tools, drill sizes, and tapping bits on hand.
We acquired and assembled the Shop Press; then took measurements to be able to produce a 3-Dimensional CAD file.
The provided CAD file is a close approximation of the machine's intended dimensions, slight discrepancies and the inaccuracies due to the consequence of mass manufacturing were rounded to common measurements.
