After mining for a bunch of solutions on other projects, I'm back in this mineshaft. Now that I've got a redesigned Tetent Timespy, I know what changes I can make here that will improve both solutions. I've gone all Dynamic Island on the belt path by increasing the length from 35 to 40mm so that I can reduce the PCB height by 1mm whilst getting more PCB area that can be used for components. The belt length has also increased from using a 92mm to a more readily available 100mm belt.Sigh... now my entire PCB solution will have to be recalculated.
