[M][L] Dual 1.14" PCB (and prototype's CAD and eCAD finished)
A project log for Tetrinsic [gd0041]
A motorised fader that is continuous, pressure sensitive, haptic and water resistant.
kelvinakelvinA 07/18/2023 at 05:590 Comments
So I've spent the past 6.5 hours working though Fusion 360 crashes to bring Tetrinsic v361 into existence. I've replaced the old 1.47" pad with a new custom pad for a PCB that connects the two screens, converted the FPC of the displays into sheet-metal components (so that I can adjust the bend radii and position) and adjusted the pressure plate, as seen below.
The routing of the PCB was a bit of a rushed job, but I think it still turned out elegantly. I havent' really done all that much in terms of silkscreen though.
The pinout of the connector is shown here:
The pins were chosen such that it was possible to route the traces on the Tetrinsic PCB. Sadly, I had like 3 crashes just doing the last trace. This reminds me of what Fusion 360 3D design used to be like. It seems I'm only getting crashes when routing a trace.
I'm also thinking about using 4mm alignment pins for the BLDC too, to reduce the amount of unique components. I was planning to use that extra space on the sprocket for a grub screw, but I don't think I'd be able to fit it in anyway and a friction / glue attachment should suffice instead.
Now that I'm writing this log, I'm looking at the cutout for the 1.14" screens and it seemed like I should reduce the width to increase the strength of the pressure plate due to more material available on the sides:
It's actually starting to look somewhat professional now.
[Spoken like an Apple executive who's summarising a new product as the summary slide animates in]: So there you have it. After 361 saves, this project concept has grown both in size and featureset and is now electrically and mechanically complete (unless I'm forgetting something). I won't know if it's manufacturable until I try, though.
Oh wait, there's something not quite right about the pressure plate fillet screensnip above...
Ah. Fixed. Ok, 362 saves.
