I've updated the load cell and I think I can still obtain a solution.There's still enough geometry here to use to prevent rotaional movement. The entire length increases by about 3mm I think, but I needed to move the Tetrinsic offset in TimerSpy closer by 5mm anyway-- noh way it actually became ever so slightly shorter not 3mm longer!
