- Tweaked the symbol so that the SPI part is consistent. I forgot to swap the oders of the text though.
- The interrupt pins are used for detecting different situations while using low power, so it seems important.
- I'm not sure how to set pins as NC like in EasyEDA. Perhaps it's not needed in Fusion360.
- I'm just using the circuit provided in the datasheet.
- Time taken: About 30 minutes.
