I wasn't expeecting these to cost so much. Ther more I started researching into other options, the more I was wondering why I was bothering with both a cable that goes to Tetent and 2 cables that go to neighbouring Tetrinsics. It would be cheaper and neater to just have a higher-pin-count cable go out. This way, I could even put VBLDC on the FPC since it would just need to handle the current of one motor.
kelvinA
