The concept print: https://hackaday.io/project/184181-tetent-gd0090/log/221171-p-concept-half-print
Essentially, I'm going to have to mandate that 18mm thickness I just so happened to acheive when switching to this 3.2mm ball chain solution. I've also got to aim for a slope angle of 18 degrees.
Solar Cell
First, I wanted to research on my off-the-shelf solar panel options. I have a feeling that I could always cut down a larger panel if I get the process right, but off-the-shelf reduces manufacturing requirements on an already multi-fabrication design (wire bending, 3D printing, PCBA, aluminium milling).
First thing I saw was this:
Something felt kind of... off, since I probably would've been fine with this already if I got 0.25A from one. It turns out that most of them are understandably only 0.1A:
I was able to find one that produced 0.16A, and it visibly has more solar panel area inside:
Oh wait. I just found the below video. It's super easy -- barely an inconvinience -- to cut a cell:
That means "reality can be whatever I want". The cheapest, highest efficiency cell that I can cut to size would be the 78x19mm cell I found earlier on, but it's more efficient from a cost and manufacturing standpoint to cut 2 panels at once from a 78x39mm cell:
There's also a seller that has a 15mm wide kit:
Modelling
Sometihng interesting to know is that, if spaced precisely 18mm apart, I'd achieve a 18-ish degree "stagger" with a horizontal spacing of 19mm:
Anyway, the new design is a rather long 104mm:
That, along with the steeper angle, makes for some issues downstream:
kelvinA
