Just a quick update:
I had to make the skeleton side profile larger because the edge that my cursor is pointing to has to extend past the moving ball chain. I've also added a cutout so that the antenna connector can make its way out:
A project log for Tetrinsic [gd0041]
A motorised fader that is continuous, pressure sensitive, haptic and water resistant.
