Everything else in the layout is more or less macros.
"Dry Run" is typing a chord and it showing up on the screen only, instead of it being shown on screen and sent to the host device.
"Tetent Search" is a very important feature. Like I said, there's 2196 possible chords. Almost every Hackaday article that features a chording keyboard has complaints about the time-to-learn of it. Hopefully, potential users will stick around long enough to learn the single character chords. With that knowledge, they'd be able to search for any of the other keybinds.
"Switch Sides" is to toggle between the current Tetent being used for the left or right hand. All 0X0 macros are there so that they remain invariant between toggles.
I've been able to add F21 - F24 into the Function section of the keybind space.
300 to 399 are for numbers "00" to "99". 3A0 to 3A9 are for numbers "0" to "9".
These are all the other macro keybinds I have:
That fits everything! I don't even have to use AXX, BXX or CXX. It's probably not going to last though, as I'd like to put mathematical symbols into AXX so that I can write and work out maths equations way faster than if I was using old fashioned pen and paper.
[3rd Sep 2022]
