Tetent as modelled in https://hackaday.io/project/184181/log/211077
Width increased from 185 to 190mm.
The screen holders have been increased to the same length as the two Tetent's, which is currently 214mm. The print thickness has decreased slightly from 12 to 11mm so that they'd fit. This decreases the pressure exerted on the screens, and should make the tablet stand and laptop mode more stable.
Wed 21st Sep
Following the PCB design of #Tetrinsic [gd0041], I've updated the branding of #Tetent [gd0090] and Teti.
kelvinA
