[R - E1] Multiwall Polycarbonate
A project log for SecSavr Sublime [gd0036]
An FFF 3D printer that I described as "The FULL Coverage, Extended X, Pro Max, Ultramatrix Solution"
kelvinakelvinA 03/10/2022 at 14:535 Comments
I've stumbled on this listing that has much more useful information.
[E[number] = Edit added]
Edit 1
I've found this printer that uses multi-wall polycarb for the enclosure while just searching around on Hackaday. Most enclosures I found for CNC's were made from MDF and I believe most 3D printer enclosures are acrylic, so it's nice to see what this materal looks like when enclosing a printer.
Daniel Grace wrote 03/10/2022 at 15:31 point
Does the 10mm and 16mm have the same amount of internal walling? Thickness of the trapped gas area should improve things, but the number of internal walls will also have a big impact, if I understand things correctly. So if 10mm and 16mm have the same internal structure, I'm not surprised it doesn't improve much. But 2 layers of 10mm will have double the walling, it should be much better. Ideally you want a gap between the two 10mm panels to make optimal use of the inner layer.
kelvinA wrote 03/10/2022 at 16:15 point
10mm is twin-wall and 16mm is triple-wall. If I use the dual panel approach, the air gap would be approx 22mm (42.4mm - 10mm - 10mm). There's also 25mm that looks to have 5 walls.
Daniel Grace wrote 03/10/2022 at 16:17 point
Oh interesting. 16mm AND triple wall and still no change in the listed specs? That makes no sense to me, I wonder if it's a typo/copy-paste error or there's something we're missing...
kelvinA wrote 03/10/2022 at 17:06 point
I've found
 - https://plaskolite.com/docs/default-source/tuffak-assets/technical-documents/noise-reduction-msc122.pdf
and even with solid 6mm polycarb and a 30mm air gap, noise is only further reduced by 4dB
Daniel Grace wrote 03/10/2022 at 17:36 point
4db can be quite significant, given it's a logarithmic scale. Though that does feel like a pretty small increase for the material.
