A project log for SecSavr Sublime [gd0036]
An FDM 3D printer that I described as "The FULL Coverage, Extended X, Pro Max, Ultramatrix Solution".
So I started to write the dependencies of components down and realised that Room > Frame > Gantry > Slime is wayyyyyy better than trying to go the other way around. Thus, I'm currently modelling the location in the room where the printer is going.
Edit 1
Edit 2
Quick render:
eeeeeeeee
Yes, delete it Cancel
