[G] = Generic Progress Update
I've been meaning to get an M6 tap for a while to fix the threads in the 30mm aluminium spacers I bought months ago, but today I thought that I might as well ask my uni's workshop if they have one.
So with the M6 tap the uni's workshop just happened to have, I got to work. I bottommed out, flipped the spacer and threaded from that side too for good measure.
Then I got the long M6 bolt to try the threads.
- "How much more do you need?"
- "About 5 milimetres."
Then he goes to a machine [below] that I assume is some kind of sander and grinds away at the tap for 1 - 2 minutes.
Wow. I was not expecting that. I try it and it goes through pretty nicely. Moment of truth; does the bolt thread through?
Success.
Now I didn't want to find myself wishing I tapped more, and I had the other 19 spacers in my pocket, so I tapped them all.
- Insert spacer into vice.
- Put tap in thread and turn it once by hand.
- Put on the tap handles and spin the tap with just my left hand until noticable resistance.
- Turn with both hands. The left hand is always in contact with the handle and the right hand lets go to grab it again.
- On the 4th time the right hand grabs the handle, turn the tap back 270 degrees.
- Continue 4 and 5 until I've gotten through the spacer (and bottomed out)
- Unscrew the tap by turning it 32 times, then take off the handle and manually unscrew until it comes off.
- Insert the 50mm M6 bolt and then the allen key.
- Screw the bolt in until very low resistance (the bolt freely rotates with almost no friction)
- Unscrew the bolt. Take out the spacer and tap it to remove shavings.
- Do steps 1 - 10 for the remaining bolts.
Now I've got to put the test hotend back together again to see what the temperature difference is between 3 9mm spacers and 1 30mm spacer.
[E1: 23 June, 20:31] The melt zone extender looks suprisingly professional.
