This is the concept model of one of the tiles. The frame is 4040 alu extru and the motors are all Nema 14 except for the N23. The front tile is a 256x256mm LED matrix and the back is an array of COB leds for backlighting effects.
One of the main positions I wanted was for the tile to be planar with the ground, so something like Fluidum wasn't going to work. I also want these tiles to be quiet as I intend to have them running in the background, so hobbyist servos were also not an option. I've already bought 200 Nema 14 motors.
3 Axis
Originally, I only wanted to go with a 3 axis tile, but the concept turned out to be too large and likely too wobly to work (not like an arm configuration is any stiffer)
Reducers
For the motors, I've opted for a harmonic drive that I currently haven't tested. It's currently a 17:1.
Looking at results from other peoples designs, I'm thinking of going from a dual bearing to a triple bearing to increase the amount of teeth engaged.
