This is a angle gauge based on a Arduino nano and MMA_7455 g-force sensor.
The Nixie tubes are from ITT called 5853 S made 1972 (Week 42, 50 & 52) in England. The tubes should be driven at 11 mA, but i only do 1,4 mA - They still glow. The driver chips are binary to decimal converters probably for this usage developed from Siemens (74141) produced in 1973 (Week 5 & 27).
The firmware is using a moving average for a smoother display. A clever and simple way to convert the calculated angle to binary did not work out as planed.
Next to the angle this thing should be able to integrate the speed with the measured acceleration over time witch will be testet soon. A proper housing is also planed.
Thank you! I am still perplexed every time how fine everything still work together. A sppedOmeter will be my next goal. Maybe a switch to change modes.
👍 Cool combination of retro display technolgy with modern computing power.
