it is used for sanding inside of the pipe.
for this project you need a 3d printer and one long bolt with some nuts
See Tutorial Video Here:
Standard Tesselated Geometry - 71.47 kB - 03/09/2022 at 19:33
Standard Tesselated Geometry - 39.05 kB - 03/09/2022 at 19:33
Standard Tesselated Geometry - 684.00 bytes - 03/09/2022 at 19:33
MasterOfNull
Brian Brocken
Conrad Brindle
Yes, delete it Cancel
You are about to report the project "TOOL FOR SANDING THE INSIDE OF THE PIPE", please tell us the reason.
