1Introduction
As RTL8722DM MINI has a built-in microphone on the board, there is no need for any external microphone. Copy a sample wav file into the MicroSD card for demo. (In this example, the sample name is “Test_Audio_48khz_16bit_stereo.wav”. ) Then insert the MicroSD card into the adapter at the back of the board.
2​Example 01 PlaybackWavFile
Open the example, “Files” -> “Examples” -> “AmebaAudioCodec” -> “PlaybackWavFile”.
Upload the code and press the reset button on Ameba once the upload is finished.
Insert earphones/speakers into the onboard jack for playing the sample sound. -
3Example 02 RecordWavFile
Open the example, “Files” -> “Examples” -> “AmebaAudioCodec” -> “RecordWavFile”.
Define a GPIO/button(Input high to active) for “RECORDBTN”. Define the “filename[]” for the name of the storge wav file. In this example, the name is “Test_Recording_48khz_16bit_mono.wav”.
Input high to “RECORDBTN”, then record voice by the onboard mic. When the input is low the record stops. The recorded voice will be stored in “Test_Recording_48khz_16bit_mono.wav” located on a MicroSD card. -
4Example 03 RecordPlaybackWav
Open the example, “Files” -> “Examples” -> “AmebaAudioCodec” -> “RecordPlaybackWav”.
This example is a combination of Example01 and Example02. You can record by Example02 then play it by jack as the method of Example01.
Define a GPIO/button(Input high to active) for “RECORDBTN”. Define the “filename[]” for name of the storge wav file. In this example, the name is “Test_Recording_48khz_16bit_mono.wav”.
