The targeted decoding ROM is going to have 8-bit output. Under such restriction, the number of microcodes has to be not grater than 2^8 = 256 = 16 x 16.
Operation / Data Flow | Coding Space | Comment |
B < B1 < Bus-C < Reg B > B0 > Bus-B > Reg | 2 x 16 | Totally 16 registers in reg-file |
A1 < Bus-C < Reg A0 < Bus-C < Reg | 2 x 16 | |
B < ALU < Bus-A < A1A0 | 2 x 16 | 74LS181 has 5 lines selecting 2 modes by 16 functions |
PC1 < Bus-C < Reg1 PC0 < Bus-C < Reg0 | 1 x 16 | PC1 may only be loaded with odd numbered registers. 1 x 8 PC0 may only be loaded with even numbered registers. 1 x 8 |
PC1 > Bus-A > ALU > B >> Reg1
PC0 > Bus-A > ALU > B >> Reg0 | 1 x 16 | |
MEM < Bus-C < Reg MEM > Bus-B > Reg | 2 x 16 | |
C1C0 < Bus-C < Reg | 1 x 16 | |
D1D0 > Bus-B > Reg | 1 x 16 | |
SL(B)1 SL(B)0 SR(B)1 SR(B)0 | 4 | Shift Left (B) one bit and fill 1
Shift Left (B) one bit and fill 0 Shift Right (B) one bit and fill 1 Shift Right (B) one bit and fill 0 |
0(ALU) > B1 > Bus-C > MEM 1(ALU) > B1 > Bus-C > MEM 0(ALU) > B1 > Bus-C > C1C0 1(ALU) > B1 > Bus-C > C1C0 | 4 | All bits with 0 All bits with 1 Generated by ALU 74LS181 |
C1 > D1 C0 > D0 C1 > D0 C0 > D1 | 4 | |
IO < C1 IO < C0 IO > D1 IO > D0 | 4 | |
IMM > D0 IMM > D1 | 2 | |
IMM > IO | 1 | |
0(ALU) > B > Bus-B > CycleCounter | 1 | Reset CycleCounter to 0 |
StatusFlag < Bus-B < B0 < B | 1 | |
IR < Bus-B < MEM | 1 | Fetch instruction from memory |
A++ | 1 | 32-bit {A1, A0} increase by 1 |
PC++ | 1 | 32-bit {PC1, PC0} increase by 1 |
number of microcodes in total | 216 | = 6 x 2 x 16 + 4 x 4 + 2 + 6 |
An extra "SILENT" operation, to silent all buses and control lines, with the ClockCounter still working increasing, might also need be coded.
The bus architure has been modified again to make coding in 16x16 feasible. Also smaller number of ICs is preferred.
![A1 bus architecture v3 A1 bus architecture v3](https://cdn.hackaday.io/images/3939831647428153835.png)
