1Print spacers
Print four parts with PLA. STLs are available under /openscad.
Since it's all written in OpenSCAD, you can easily make the parts fit to your photo frame.
2(Optional) Solder wires to spring plates
If you'd like to use a LiPo battery instead of three AAA batteries, you can skip this step.
Solder a pair of wires to metal battery contacts.And then insert them into the spacer.![]()
3Attach spacers onto EPD module
With M2*5 screws, tightly fix the spacers onto the EPD module as follows.
4Put everything into the photo frame
5(Optional) Prepare wall mount
If you'd like to hang the device on a wall, you can print `smp7c_stapler_wall_hook.scad` and fix it to the wall with a stapler.
6That's all!
likeablob
