1Hardware
I used a WEMOS ESP32 board that has a 18650 battery holder and the charger circuit included so the build it's really just attaching buttons and fit it in a suitable case.
But then I also made some Push Push Air without battery (powered via the usual USB calble) with a classic ESP32 dev bpoard.
Any EXP32 developement board shuld be ok to run the Push Push Air code.
2Software
Device Customization
By default the pedals/buttons are connected to Pins
21and23, and the only led used isLED_BUILTIN, however you can customize this.The PIN and LED assignement is done in a separate file, named
customize.hSee the GitHub repository Readme for details on how to customize that file.
Compiling the firmware
If you are using the same board with integrated battery that I used, in Arduino IDE select the WeMos WiFI&Bluethooth Battery
Otherwise select the board you are using
As Partition Scheme select: Huge APP (3MB No OTA/1MB SPIFF)
Please install the following libraries:
BleKeyboard 0.3.2beta
- Bounce2
- Preferences
- Pangodream_18650_CL
Stefano Garuti
