Ceiling Mounted vs. Free Standing VR Support Rig
03/26/2022 at 14:13 • 0 commentsI currently have two VR support rigs that are meant to be used with my passive VR shoes.
Similarities
Both rigs support
- Crouching (crouching height is adjustable)
- Sitting
- Walking while turning.
- The platforms are the same, so they have the same noise reducing materials.
- The platform can be leaned flat up against a wall for storage.
- No welding required to build either rig.
Ceiling Mounted Rig Pros and Cons
- Pros
- Less time to assemble since there are less parts.
- There is no resistance to turning. It's like butter. It's also completely silent.
- Smaller size. Rig can be stored up on the ceiling, or the majority of it can be stored in a small closet.
- It's easier to make the platform as large as you want. The platform is also not required to be elevated.
- Cons
- Requires bolting into the ceiling.
- It's bolted to one spot, so it can't be moved around.
- Requires a lower ceiling. My ceiling is 7 feet tall in the basement where I have it set up.
- Height is not as adjustable as with the other rig.
Free Standing Rig Pros and Cons
- Pros
- Bolting into the ceiling is not required.
- Can be moved around. It weighs about 50 pounds. I can easily drag or push it around my basement.
- Height is more adjustable than the other rig.
- Cons
- More parts, so takes more time to build.
- Turning as some resistance. I find the resistance comfortable and am not bothered by it, but it is noticeable, especially when switching between the two rigs.
- While playing, I don't notice it, but turning has some noise.
- More time to partially disassemble to store away.
- I've designed the platform to be 42in in diameter. It could be made bigger, but would require designing and building a bigger octagon. The platform's edge must be elevated, which I use layers of polystyrene to do.
My Preference
After using both rigs for extended periods of time, I prefer the ceiling mounted rig. I realize this rig is not an option for many people. I prefer it mainly because turning while walking has no resistance. It also has the advantages of less parts and a simpler platform design.
In the Future
In the future I may design and build a 3rd support rig. This rig will take my ceiling mounted design and instead of bolting it to the ceiling, couple it to something like the frame of a swing set.
Differences Between This Support Rig and Similar Devices
03/24/2022 at 23:06 • 0 commentsThe most similar looking device to my DIY rig is the Kat Walk C.
Both the devices have slanted tubes/bars of metal that extend up to a section that has a harness. In my case a climbing harness with leg straps, whereas the Kat Walk C uses a large waist strap. They also both have platforms that are circular. However, there are many non-trivial differences between my DIY device and the Kat Walk C, and other similar devices such as the Virtuix Omni.
Extra Features
My rig supports sitting because the climbing harness has leg straps. If the kat walk C had a strap that had leg straps, and the crouching distance was expanded, it could too, but it currently doesn't.
My rig has a larger range for crouching than the Kat Walk C. It supports tilting forward as well. Lastly, the height of the rig is adjustable.
Reduced Weight
My rig all together weighs 51 pounds (27.4 pounds from the platform, 23.6 pounds from the rig). The Kat Walk C weighs 128 pounds.
Noise Reduction
From the picture above, you can see that underneath the Kat Walk C's platform are a series of legs that extend out from the center. I build a similar design, which I went over in this build log, but one of the reasons I decided against it was because it was louder than just having the platform rest on the ground.
I decided to go with a design that maximizes the surface area in contact with the ground, as this reduced the noise more. The platform consists of 1.5in of polystyrene, a layer of thin carpet, a 0.75in thick piece of plywood, and another layer of thin carpet. The carpet, polystyrene, and large surface area with the ground reduces noise more. You can watch some of my demos here where I also recorded the sound the rig makes. The noise made while walking is relatively quiet. Unfortunately running is still loud.
Platform Differences
The Kat Walk C and other slidemills use a curved, bowl shaped surface. My platform is completely flat to make it easier to build. It's covered with a thin layer of carpet to reduce noise and also to increase friction with the VR shoes a little bit. Obviously, instead of sliding on the surface, I use overshoes with wheels.
Easier Construction
I designed the rig so it would be relatively easy to put together.
- It doesn't require any welding.
- Most of the metal is conduit which is easy to cut and drill holes in. It's also light-weight.
- It uses an octagon with rollers that grip the edge of the platform. This made the platform design easier, as I didn't need a large strong bearing underneath the platform in the center, and didn't need legs holding up the platform. It's also an octagon instead of a perfect circle because an octagon is much easier to make than a perfect ring.
Adjustable Height
03/24/2022 at 22:46 • 0 commentsThis support rig allows for height adjustment. The long two slanted tubes that connect the octagon to the top part the user straps into are telescoping tubes. These are photos of the different heights with me in the background as a reference. I'm 5ft 11in tall.
Above is the lowest setting I set up. More holes on the telescoping rods could be drilled to go lower by a maximum of about 5in.
Above is the highest setting. More holes cannot be drilled to increase the height.
This is the height that I personally use.
