This is a very interesting and easy to make project. This device will detect whether there is any current or not from a quite long range.
arfg.PNGPortable Network Graphics (PNG) - 115.52 kB - 03/24/2022 at 08:57 |
Gerber_PCB_AC DICTOR_2021-12-29.zipZip Archive - 27.75 kB - 03/24/2022 at 08:56 |
This is a very interesting and easy to make project. This device will detect whether there is any current or not from a quite long range. This project is known as "Wireless Voltage tester ".
Step 1:- Get your PCB ready!
Talking about electronics
Related Download files:-
Step 2:- Get all the components listed below in the images.
Step 3:- Place all the components on PCB and solder it properly.
Step 4:- Stick the PCB in custom-designed PVC sheet Box as shown in picture below with the help of Glue gun.
Final step:- Cover the box and place all the components of PCB on their respective holes or places. And at last Connect it to a 9-Volt battery and place it inside the box by double sided tape.
New users will also get some coupons while registering at JLCPCB via this blue link
Thank you for reading this guide, hopefully, this guide provides full steps to help you to create your own Wireless Voltage Tester. If you have any questions please post them in the comment section below.
