- Tweezers that I bought are ribbed, ended up losing on of the 1kohm 0201 resistors due to this, bought replacements that should arrive tomorrow
- Successfully soldered R68, R69, R71, R72
- Somehow destroyed the resistor I connector to the R70 pad, it measures as an open circuit
- Instead of heating up the pad then touching it with solder (when trying to apply solder to the first pad) I would sometimes do the opposite when soldering 0201 devices, this lead to large solder balls being developed, my attempt to de-solder one of these balls let to one of the pads of R60 to be ripped out
