- New precision tweezers have arrived, soldering 0201 components has become a lot easier
- Soldered R18, R31, R36, R51
- Soldered R61, R63, R64
- Soldered C15, C16, R73, R74, R57
- Soldered R2, R41, R50, R4, R11, R12
- C47, C48, C49, C52, C53, C57 and C58 are supposed to be 1uF, bought 100pF by mistake
- U1 ground pin by C61 needs to be soldered
- 'Cleanliness' of the solder tip has a huge affect on ability to solder properly, if too much oxidation (I'm assuming that's what this is) the solder won't adhere to the tip, may need to buy the tip cleaner substance
Ghani Lawal
