- Soldered R55, R54, R52 and R49, lost R59 when I opened the package
- Soldered R40, R42, R43, R44, R45, R46, R47
- Soldered R32, R33, R37, R38
- Soldered R20, R23, R24, R25, R26, R27, R28, R21 got attached to the solder tip and ended up getting destroyed
- **R40 and R33 both differed by their nominal value by over 10%... don't know if I was sent the wrong resistor or if I damaged the resistors as I was soldering them
Ghani Lawal
