An interface is constructed using 3D printing and a simple PCB. Which can be used to connect the screen-printed electrode to the pin of a potentiostat. Usually, crocodile pins are connected to the screen-printed electrode, which makes it clumsy and difficult to operate (for example: performing cyclic voltammetry). A simple and easy to construct interface is proposed which can be a one-time and less time-consuming investment for a researcher.
Files
bottom plate of 3D printed case.stl
A bottom plate is attached to the PCB for support
Standard Tesselated Geometry -
511.60 kB -
03/28/2022 at 18:53
The PCB is used in single-sided PCB. The tracks on the PCB are made using CNC machines and the gerber file "PCB gerber" is accessible in this file section
Adobe Portable Document Format -
3.53 kB -
03/28/2022 at 18:53
