1Visit the GIthub link above
It has all the important files and source code for the project
2Arduino IDE board installation
Add this following line to the "Additional Board Manager URLs",
Then install Ameba package from the board manager
3Upload the code
Use Arduino IDE to upload the code in the Github repo to Ameba
43D Print the case
You can either do it yourself or find someone else to print for you, its 2 small object, prince should be quite ok
5Assemble!
Follow the connection found in the code to connect all the parts together
6Set up your MQTT client on the mobile app and have fun!
