I want to make dual power supply unit for my amplifier boards, most of them are of 200w to 400wats. So, I need a stable, filtered and high-power components with durable base. Making of any linear power supply filtering and rectifying circuit is not too much difficult but the components play a huge role.
![](https://cdn.hackaday.io/images/5978091648706167496.jpg)
In this tutorial, we will see how I completed my power supply unit and components used.
Amplifier needs:
![](https://cdn.hackaday.io/images/7145471648706198194.png)
Here you can see I have some stereo and mono amplifier boards, but some of them don’t have good filtration capacitors and proper rectifying unit. And in some of my projects I need dual channel power. 24-0-24 or 12-0-12, with a 3 wired transformer. I want to make a power supply filtration and rectifying unknit that is not only give dual channel but also on different voltages of 12v and 24v.
Components required:
![](https://cdn.hackaday.io/images/2549041648706254309.jpg)
1) BR1010 10-ampere rectifier
2) 10A fuses
3) 24,12v toroidal transformer
4) IN5408 diodes
5) 4700uf/50V keltron Capacitors
6) Custom PCB (JLCPCB)
Transformer:
I am using a toroidal transformer, but Iron core also works fine. This toroidal unit works on 220v AC and give output of 24-0-24, 12-0-12 and 0-12. But we need only first two channels of 24 and 12 volts. So, we will make a circuit according to this transformer output voltages with 24 and 12 dual channel power. Maximum current ratings of this transformer are 10Ampere.
![](https://cdn.hackaday.io/images/2725391648706302720.jpg)
I don’t use Iron core; they are bulky and not too much powerful. Also, the output current and voltage is limited to one or two channels.
Circuit diagram:
I came up with an idea of making schematics in EasyEDA and here is my designed circuit. This one has 6 filtration capacitors, 4 diodes and 1 big high-power rectifier. The circuit diagram is out of knowledge without connecting points. You can use My files to Order PCB from JLCPCB.
![](https://cdn.hackaday.io/images/134271648706352943.png)
Then we will make a PCB prototype to use this project practically, without PCB all things and circuitry will be messed up and I don’t want to blast or explode anything in this high-power circuit. JLCPCB is sponsoring this project and their PCB prototype service is very amazing, I got the 5PCS of this PCB in Just $2. So, check out to JLCPCB from this link here and get extra reward coupons.
PCB:
Download PCB Gerber files from here.
![](https://cdn.hackaday.io/images/2102321648706370138.png)
Sign-up to JLCPCB using this link and you will get free coupons of worth $27.
Circuit description:
we can give two different voltages simultaneously from this circuit in dual voltage. -24 to +24 and -12 to +12. I am using 10 ampere rectifiers for 24-volt operation and 5408 diodes for 12v. Keltron 4700uf 50V capacitors are for filtration, because they are known as best quality highly stable capacitors.
![](https://cdn.hackaday.io/images/2611391648706456269.jpg)
Yep, 10Ampere fuses are mandatory when working with such a high power. These are connected to transformer output, if any short circuit happens the fuses will cut off the supply from main linear unit.
Assembling and soldering:
First, I mounted all the diode. I tried to keep them in air so that they can dissipate heat faster.
![](https://cdn.hackaday.io/images/3608371648706539536.jpg)
Then I go for main rectifier br1010 (10amps) and fuses.
![](https://cdn.hackaday.io/images/6505551648706555502.jpg)
After this I placed all the capacitors and soldered them properly and here are the beautiful looks of this circuit.
![](https://cdn.hackaday.io/images/9954051648706577246.jpg)
The overall finishing work done by JLCPCB is really very decent in that price and white color is what making it more cooler.
Working: With 12v:
![](https://cdn.hackaday.io/images/original/1086621648706602973.gif)
With 24volts:
![](https://cdn.hackaday.io/images/original/6773711648706618830.gif)
PCB ordering Process from JLCPCB:
The PCB ordering process is very easy, First sign-up to JLCPCB and upload your Gerber files.
![](https://cdn.hackaday.io/images/1800441648706771473.png)
Then choose material, color, quantity, thickness and surface finishing.
![](https://cdn.hackaday.io/images/9947181648706796912.png)
Add your PCB prototype in cart and checkout, you will get the package in just 7 days.
![](https://cdn.hackaday.io/images/788251648706811207.png)
Wants to know more about SMT service then check this post.
another project which mostly serves as JLCPCB advertisement
