The first steps walking:
Some of the build Process:
A chronology of my previous projects, leading up to the powerarmor:
The power armor is a Hybrid Active/Passive Powered Armor (HAPPA) made cheap as possible. By using simple relays and electrical linear actuators to articulate the arms, diagnosis, maintenance & repair is easier than using multiple motor controller systems.
The legs are passive, meaning the armor's weight (currently 113lbs) are supported on the joints via elastic cords and springs.
While not particularly practical, it is a showcase of what can be done on a limited budget with a little creativity.
