1Frame
Materials:
1600 linear mm of 2020 V Slot Channel
https://www.amazon.com/dp/B09DYMCBYF?ref=ppx_yo2ov_dt_b_product_details&th=1Qty 10, 90 Degree Angle Brackets Interior Joint Corner Bracket for 2020 V (or T) slot
https://www.amazon.com/dp/B07PJ8H5ZQ?ref=ppx_yo2ov_dt_b_product_details&th=1Cut the V channel into the follow pieces:
Qty 4, 148mm length
Qty 2, 480mm length
Qty 3, 220mm lengthPosition and assemble as show.
2Elevator axis gantry
Materials:
Qty 1, 210mm 2020 V Slot Channel
https://www.amazon.com/dp/B09DYMCBYF?ref=ppx_yo2ov_dt_b_product_details&th=1Qty 2, 2020 Aluminum Profile Pulley V-Slot Build Gantry Plate with V wheels
https://www.amazon.com/dp/B08NDMVM42?psc=1&ref=ppx_yo2ov_dt_b_product_detailsQty 2, 90 Degree Angle Brackets Interior Joint Corner Bracket for 2020 V (or T) slot
https://www.amazon.com/dp/B07PJ8H5ZQ?ref=ppx_yo2ov_dt_b_product_details&th=1Qty 4, 2020 V (or T) slot Series Corner Brackets
https://www.amazon.com/dp/B095JSJTPX?psc=1&ref=ppx_yo2ov_dt_b_product_detailsQty 4, M5 T-Slot Nuts
https://www.amazon.com/dp/B095JSJTPX?psc=1&ref=ppx_yo2ov_dt_b_product_detailsAssemble as shown
3Elevator axis motor assembly
Materials:
Qty 1, 5202 Series Yellow Jacket Planetary Gear Motor (13.7:1 Ratio, 435 RPM, 3.3 - 5V Encoder)
https://www.servocity.com/5202-series-yellow-jacket-planetary-gear-motor-13-7-1-ratio-435-rpm-3-3-5v-encoder/Qty 1, 3417 Series 5mm HTD Pitch Set Screw Pinion Timing Belt Pulley (6mm D-Bore, 16 Tooth)
https://www.servocity.com/3417-series-5mm-htd-pitch-set-screw-pinion-timing-belt-pulley-6mm-d-bore-16-tooth/Qty 1, 3412 Series 5mm HTD Pitch Timing Belt (9mm Width, 890mm Pitch Length, 178 Tooth)
https://www.servocity.com/3412-series-5mm-htd-pitch-timing-belt-9mm-width-890mm-pitch-length-178-tooth/Qty 1, Flanged Ball Bearing 6x15x5mm
https://www.amazon.com/dp/B07Z3F1MR5?ref=ppx_yo2ov_dt_b_product_details&th=1Qty 4, M5 T-Slot Nuts
https://www.amazon.com/dp/B095JSJTPX?psc=1&ref=ppx_yo2ov_dt_b_product_detailsQty 1, Elevator axis motor assembly left mount (3D Printed)
See 3D print filesQty 1, Elevator axis motor assembly right mount (3D printed)
See 3D print filesAssemble
Mount to V Rail with the belt (not shown here)
With belt shown here
4Elevator axis pulley assembly
Materials:
Qty 2, Flanged Ball Bearing 6x15x5mm
https://www.amazon.com/dp/B095JSJTPX?psc=1&ref=ppx_yo2ov_dt_b_product_detailsQty 1, Elevator axis front left pulley mount (3D printed)
See 3D print filesQty 1, Elevator axis front right pulley mount (3D printed)
See 3D print filesQty 1, Elevator axis front pulley (3D printed)
See 3D print filesQty 1, M6 X 64mm screw + 1 washer + 2 nuts
Assemble (screw not show here)
Mount to V Rail with belt (screw and belt not shown here)
With screw and belt shown here
5Elevator axis belt lock
Materials:
Qty 1, Elevator axis belt lock, upper (3D printed)
See 3D print filesQty 1, Elevator axis belt lock, lower (3D printed)
See 3D print filesQty 2, M5 T-Slot Nuts
https://www.amazon.com/dp/B095JSJTPX?psc=1&ref=ppx_yo2ov_dt_b_product_detailsMount as shown with belt (belt not shown here)
Shown with belt (bottom view)
