board tester, we have boards
A project log for PDP-11/70 replica
Recreating boards for those old computers, and improve on them
sxpertsxpert 05/28/2023 at 10:341 Comment
It's been a while, lots have been happening at $dayjob, and time has been an issue lately (that, and funds for components)
I had ordered boards from PCBWay back in february, received them some time later, then time-crunch hit, and I had no time whatsoever to do anything on the project.
those boards are beautiful, look at them !
and here is the stencil...
Again, thank you very much to PCBWay for sponsoring this project with their PCBs
Now, I need to scrounge some money to give to DigiKey 🤣
Geoffrey Frost wrote 05/29/2024 at 14:21 point
does this project need a boost? Do you have schematics for the other boards?
Do you have the outine/connector design for the boards?
Do you need someone to start producing artwork for the other boards
Have you any ideas for the backplane?
I normally artwork in smd but it depends on the component availability.  Certainly all passives and any bog standard parts.
Help here if you need it.
