A demo of a prototype
12/09/2016 at 21:36 • 0 commentsSorry about the delay, I've been busy for these past few weeks with various activities including configuring a new laptop. Anyways I got a chance this afternoon to take a video of it. Sorry about it not exactly being 1080p but I don't own any "newish" camcorders (the one I used was a hand-me-down from a relative.)
Planned improvments
11/23/2016 at 03:47 • 0 commentsOkay, the bright white flickering LED on the dev board doesn't look that impressive. I've been experimenting tonight with different materials to diffuse the light and a yellow LED. It looks similar to a flickering candle. I found that a spare NyQuil-like measuring cap diffuses the light nicely although I want something a bit longer.
I just tried some wax paper rolled into a cylinder. It doesn't look half-bad but it's a bit flimsy.
UPDATE: I just added a photo of my experimentation of using wax paper to diffuse the light from a yellow LED.
It begins
11/22/2016 at 17:44 • 0 commentsOkay, I'll admit that right now the flickering LED doesn't look all of interesting. I'm brainstorming ways to make it more interesting. The journey on the other hand is a bit more interesting, and I'll be talking about what I learned in the project details and I'll talk about some of what I learned here.
Creating the program has been a good refresher as it involves things such as interrupts, ADCs, hysteresis, the watchdog timer, and more.
I did create something somewhat similar a while back under the Arduino IDE but for this project I went with using the AVR-GCC toolchain directly for a few reasons. The first reason is program size. While the Arduino IDE is very convenient to get things up and running, that conveniencence does come at a price: generally larger compiled program size in comparison to using AVR-GCC. You can make things a bit leaner by doing mostly coding things in the same way that you would under AVR-GCC such as direct port manipulation.
As I test, I decided to to a comparison of my program size at the time of this writing under both AVR-GCC and and the Arduino IDE. I did have to make a few slight modifications for it to work under the Arduino IDE but here are the end results:
AVR-GCC compiled size: 978 bytes
Arduino IDE compiled size: 1190 bytes
The Arduino IDE compiled program size is about 22% larger vs compiling it under AVR-GCC which isn't too bad but the binary generated by the Arduino IDE would clearly puts me over the HaD 1kB size limit. Now if I started using the things that you typically use under the Arduino IDE such as pinMode() it would have been much worse and I may do a demonstration of this in a later project log.
Another reason I decided to use AVR-GCC is to gain a deeper understanding of AVR microcontrollers. Under the Arduino IDE I can easily do a lot without reading the datasheet for the Attiny85, but using AVR-GCC makes me rummage though the datasheet which results me in learning some interesting things. I learned about the internal temperature sensor in the Attiny85 when I was reading up on ADC. I also learned that there is much more to PWM than what analogWrite() provides.
Anyways this project log has gotten pretty long, so I'll end it here.
