In 8mm film cameras, the shutter timing is linked to the frame feed of the film. When controlling the image sensor, the shutter timing must be detected in some way to capture an image. The captured image data is later connected and converted to video.
First, we created a time-lapse tool that uses test opencv to take a picture at a specified timing, convert it to a movie, and then output it.
Looks good.
