The best and one of a kind LoRa & Microcontroller single-chip solution, the ASR6601. The chip is LoRaWAN Helium compatible!
Hey, what's up, Guys! Akarsh here from CETech.
Today we have with us, a new module that can be the next big thing in the world of LoRa technology. We are talking about the ASR6601 SoC chip from ASR Microelectronics which is a package on its own. Why we are calling it a package is because it is a combination of a LoRa chip and a microcontroller on a single chip.
Previously, whenever we wanted to create a LoRa Project, we had to take a LoRa module and connect that to any microcontroller like Arduino, etc., and then we used to program that according to our use. This process was a bit cumbersome and it was not possible to create a small and compact project from this combination. In that kind of case, this module will be a perfect fit.
So today, we are going to have a look at this module and after that, we will be testing it with the help of an example code. So let's get straight into it.
You must check out JLCPCB for ordering PCBs online for cheap!
You can also get good quality SMT Assemblies from JLCPCB with Assembly Prices starting at an 8$ setup fee and $0.0017 assembly fee per joint. You will get a discount on shipping on your first order. You just need to upload your Gerber, BOM&CPL files to get an instant quote on PCB, components, and assembly. A DFM analysis is generated after you order the boards, allowing you to spot potential mistakes before it goes into production. You can also track order status in real-time and can get your products in your hands as fast as one week.
ASR6601 is a general LPWAN Wireless Communication SoC, with an integrated RF Transceiver, Modem, and a 32-bit RISC MCU. The MCU uses ARM Cortex M4, with a 48 MHz operating frequency. The RF Transceiver has continuous frequency coverage from 150 MHz to 960 MHz. The Modem supports LoRa modulation for LPWAN use cases and (G)FSK modulation for legacy use cases. The Modem also supports BPSK modulation in TX and (G)MSK modulation in TX and RX. The LPWAN Wireless Communication Module designed with ASR6601 provides ultra-long range and ultra-low-power communication for LPWAN applications. ASR6601 can achieve a high sensitivity to -148 dBm and the maximum transmit power is up to +22 dBm. This makes the chip suitable to be used in long-range LPWAN and has high efficiency. The total chip package is of very small size, QFN 6 mm x 6 mm/QFN 8 mm x 8 mm.
Key Features:
