the other side of the board
04/27/2022 at 08:52 • 0 commentsafter two passes on the A side, first pass ont the side B.
accident
04/27/2022 at 08:44 • 0 commentsas you can see, there's a deviation of the line, I was pushing too hard and the vise holding plate of the drill has turned instead of the aluminium plate I was machining.
As it's the first pass, it's not very important, but from then, I had to hold the base plate with the left hand while turning the aluminium plate with the right one.
the drill in action
04/27/2022 at 08:38 • 0 commentsa larger view of the system.
That creepy drill was brought on a garage sale for only 20 €, there was no more on/off switch (fond in another garage sale) but the tool holding mandrel is very stiff and has no perceptible axial movement.
routing the 160 mm diameter hole
04/27/2022 at 08:19 • 0 commentsUsing my little bench drill as a router, with an 2 mm tool, and a very small depth.
The size of the drill is just big enough to allow the plate to turn on it's central hole.
It's very long !
central hole
04/27/2022 at 08:12 • 0 commentsDrilling the central hole
the new lens board material has been found
04/27/2022 at 08:09 • 0 commentsVery hard 3 mm thick aluminium plate
making a new lens board
04/27/2022 at 08:04 • 0 commentschanging the old plywood lens board is my first step
